查看: 828|回复: 0
"百年传奇“ 保时捷porsshe改装AIRBFT空气悬挂让姿态更强大
发表于 2020-7-28 16:46:24 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Centennial legend" Porsche modified airbft air suspension for stronger posture
我一直认为,汽车改装是一种追求,一种对个性的追求,或者是满足自己虚荣心的一种方式。今天说说要说的改装就是汽车避震的改装。汽车避震的改装相对来说比较特殊,因为它既能兼顾性能,又能兼顾外观,可以说是双赢。在汽车圈内一直有一句话,“一低遮百丑。”这么一句名言。哪怕再不好看的车,只要车身降低下来,绝对能令颜值提高不少(超跑好看吗?超跑都低)。那么作为一项既能提高颜值,又能提升操控的改装,避震该如何改装呢?改装避震有几种方式呢?
I have always believed that car refitting is a pursuit, a pursuit of individuality, or a way to satisfy one's vanity. Today's talk about the modification is the modification of the car shock absorber. The modification of automobile shock absorber is relatively special, because it can take into account both performance and appearance, which can be said to be a win-win situation. There has always been a saying in the car circle, "one low covers a hundred ugliness." Such a famous saying. Even if the car is not good-looking, as long as the body is lowered, it can definitely improve the appearance? Super run all low). So, as a modification that can not only improve the appearance, but also improve the control, how to refit the shock absorber? There are several ways to refit the shock absorber?
