查看: 909|回复: 0
三菱日蚀成功改装空气避震悬挂 走出低趴风格姿态
发表于 2020-7-21 14:41:22 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Mitsubishi solar eclipse successfully refits air shock suspension to walk out of low prone style
《速度与激情》系列的主演范·迪塞尔在他的Instagram上公布了一张他手持定制版Xbx One S主机的照片,这款主机的外观设计灵感来自于1995年款的三菱日蚀,这款车正是保罗·沃克饰演的布莱恩·奥康纳在系列电影中的座驾。
Van diesel, the star of the "speed and passion" series, posted on his instagram a picture of him holding a customized xbx one s console inspired by the 1995 Mitsubishi eclipse, the car that Paul Walker plays Brian O'Connor in the series.
说起低趴姿态,将汽车稳稳落地的功臣源于后备箱这小小的气罐。运用物理气压的原理将车身升高降低!来满足改装低趴的乐趣!低趴改装风格已经成为一种时尚,贴地的车身让它比较倾向超跑,酷酷的外表很是抓人眼球,也许是因为它与众不同!
Speaking of the low prone posture, the contribution to the steady landing of the car stems from the small gas tank in the trunk. Use the principle of physical air pressure to raise and lower the body! To meet the fun of refitting low lying! Low lying refit style has become a fashion, the body close to the ground makes it more inclined to run, cool appearance is very eye-catching, perhaps because it is different!
第一次看到气动避震改装的车子到现在深深陷入其中不能自拔,也是经历了很多的曲折!也学习到了不少关于气动避震改装的知识!
气动避震的组成部分分为控制系统和气动避震桶身两大类!
For the first time, I saw the car refitted with pneumatic shock absorber, and now I am deeply trapped in it and have experienced many twists and turns! Also learned a lot about pneumatic shock absorber refitting knowledge!
