查看: 934|回复: 0
‘国内首台’三菱劲炫改装空气避震悬挂 走出低趴风格
发表于 2020-7-18 11:06:57 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"The first in China" Mitsubishi Jinxuan refits air shock suspension to go out of low lying style
在男人心中有柔弱的一面也有狂野的一面,为什么我们崇尚硬汉,因为大家都希望自己是硬汉,那么硬汉具体的特征是什么,答案就是身边的陪衬依旧要霸气十足,比如车,对于男人来说,除了喜欢追求速度的跑车,同样喜欢硬汉角色的越野车。越野的品牌很多,从国产到合资,从城市越野到户外扩展车,曾经霸道被国人称之为越野的标杆作品,其实这仅仅是对霸道车的一个肯定,并不是说其他品牌车不行,除了霸道外,能够跟它拼个不相上下的,就是今天咱们要说的新款ASX劲炫!
In men, there is a weak side and a wild side in men's hearts. Why do we advocate a tough guy? Because we all want to be a tough guy. What are the specific characteristics of a tough guy? The answer is that the foil around him is still domineering, such as cars. For men, in addition to the sports cars that pursue speed, they also like the off-road vehicles of the tough guy role. There are many cross-country brands, from domestic to joint ventures, from urban off-road to outdoor expansion vehicles. Once domineering was called the benchmark work of cross-country in China. In fact, this is only an affirmation of the overbearing car, not to say that other brands can't do well. In addition to the overbearing, what we are going to talk about today is the new ASX!
Second, the car style can be modified in the United States. Once the gas is released after parking, the car will lie down there and prevent Trailer.
