查看: 10528|回复: 0
ACCUAIR气动避震(最具有科技含量的控制系统)
气动中将
Rank: 3Rank: 3
发表于 2014-12-31 23:16:13 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
ACCUAIR气动避震
The e-Level™ 和level™封装结合的最高质量的所有组件提供给控制空气弹簧在一个方便的顺序编号。该试剂盒包括我们的顶级的,控制器的接口与level™touchpad™,vu4角阀4,5加仑的空气serviceable铝铝罐、空气过滤器、管道3 / 8“交通部生产批准的试剂盒,和最详细的安装和操作手册的在线市场。这些包是可用的与单或双压缩机的各种选项和上面所示。
触摸板和水平控制器
The e-Level™ Controller offers the ability to save three unique heights into memory at the touch of a button using TruPosition™ height sensors installed in each corner of your suspension. The key to this technology is its RideMonitor™ Mode; while parked or driving, the system will maintain the vehicle height when loading or unloading passengers or when road conditions change. All of this automatic intelligence is unnoticed by the driver, providing improved ride quality and handling characteristics for any vehicle with Air Suspension. The adjustments made by an e-Level™ Controller are so accurate that each wheel maintains its height within 1/8th of an inch and prevents "cross-loading" of Air Springs at a higher accuracy than any other method. Each system calibrates to the vehicle upon installation and then learns how your Air Suspension behaves over time.
该控制器提供的能力,level™高地进行保存到内存在三个独特的触摸按钮使用高度传感器安装在每个角落的truposition™你的混悬液。这是最关键的技术之一ridemonitor™parked或驱动模式;同时,该系统将保持车辆高度时,加载或卸载时,乘客的道路状况的变化。全自动智能unnoticed这是由驱动程序,提供改进的行驶平顺性和操纵的任何车辆和空气悬架特性。在调整由一level™如此精确的控制和保持在每个车轮的高度在1 / 8英寸和一个防止交叉的空气弹簧加载在更高的精度比任何其他方法。每个系统在车辆上安装calibrates然后学技术的空气悬架在球队表现得很。
vu4 4角阀单元
The VU4 4-Corner Valve Unit is engineered to provide the cleanest installation and most reliable operation on the market. This electronic solenoid valve unit inflates and deflates up to (4) individual Air Springs and has built-in push-to-connect 3/8” D.O.T. approved air fittings for all of its plumbing connections. The robust internal solenoid valve architecture maximizes flow rates, provides bubble-tight sealing, and guarantees operation up to 200 psi for millions of cycles. All of this technology is housed in a unique enclosure design which routes each of the solenoid wires to a single weatherproof connector, eliminating typically loose wires. This not only improves the appearance, but it also guarantees proper operation for every installation. With an overall size of only 5"x 3"x 3" and the ability to survive harsh under vehicle environments, this product is ideal for any application.
the vu4角阀单元4是安装工程提供最可靠的和cleanest the operation on the市场。这solenoid阀单元和电子inflates deflates up to和空气弹簧(4)个人有建立连接在推- 3 / 8“d.o.t.批准的空气在管道配件for its of Connections。在稳健的内部架构和solenoid maximizes流阀,提供泡沫和密封包紧,操作了数百万圈200 psi。这是在所有的科技housed隔声罩设计独特solenoid each of the which routes to a single weatherproof电线连接器,瘀typically松散的电线。improves this not only but also the appearance,包恩proper operation for every装置。size of only with an全面5“x 3 x 3”和“恶劣环境下的生存能力的车辆,this is for any应用的理想产品。
VIAIR 400C压缩机(S)
AccuAir has teamed up with Viair to offer the most efficient and reliable compressors available. When used with a 5-gallon tank, this single compressor will provide a recovery time of only 1 minute, 54 seconds (110-150 psi). For the ultimate compressor solution, AccuAir offers the Dual 400C option. When used with a 5-gallon tank, these two compressors will provide a blistering fast recovery time of only 52 seconds (110-150 psi).
accuair已经联手门维艾尔提供最有效和可靠的压缩机可用。当使用一个5加仑油箱,这种单一的压缩机将提供一个只有1分钟的恢复时间,54秒(110-150 psi)。对于最终的压缩机解决方案,提供双作用选项accuair。当使用一个5加仑油箱,这两压缩机提供起泡快速恢复时间仅为52秒(110-150 psi)。
5加仑航空铝储气瓶
Aluminum tanks are lightweight and corrosion resistant. These units are extruded and 100% TIG welded for maximum quality. The 5-gallon option gives adequate air storage for typical vehicles with 4-Corner Air Suspension. On some lightweight vehicles a single 3-gallon tank can offer adequate air storage.
铝罐的重量轻,耐腐蚀。这些单位挤出100% TIG焊接的最大质量。在选择了5加仑四角空气悬架典型车辆足够的空气存储。在一些轻型车辆单3加仑罐可以提供足够的空气存储。
hellaflush气动避震论坛   微信:hellaflush-China
